Old 09-20-2013, 07:20 PM   #21
Johnny Danger
Johnny Danger's Avatar
So, to get real Litronic movement based on the positioning arms, they must be the Porsche light? The others just self-level?
Any thoughts on what the real difference would be? I want to be reasonable.
Tim
If your vehicle came equipped from the factory with Litronics, then I would presume that it has the additional leveling feature that could only be installed at the factory at the time of manufacture.
Otherwise, your vehicle has an over the counter set of Litronics that were installed by the previous owner. As I mentioned, those kits came with a control module that was designed to rotate the low beams a certain degree in order to help fill in the high beams when activated. Since the net effect of this module is marginal to a lot of owners, many didn't even bother installing it. Again, the leveling system is independent of the Litronics themselves, and it had to be installed by Porsche at the time of manufacture. A set of Litroncs - is a set of Litronics.
