Old 09-19-2013, 08:07 AM   #13
soucorp
soucorp
soucorp's Avatar
Originally Posted by thom4782 View Post
Answer is simple - recalls occur when cars fail to comply with federal motor vehicle safety standards or have other safety related problems. IMS failures are considered mechanical problems not safety related problems.
Thanks but I disagree. We should all call NHTSA and complain, they will force the issue to a recall. If my engine blew up from IMS failure at highway speeds, the car can lose control and cause a serious accident due to loss of power and I get nailed in the back by a semi. If this scenario is not a safety concern, I don't know what is???
When is a recall necessary?
When a motor vehicle or item of motor vehicle equipment (including tires) does not comply with a Federal Motor Vehicle Safety Standard.
When there is a safety-related defect in the vehicle or equipment.
Federal Motor Vehicle Safety Standards set minimum performance requirements for those parts of the vehicle that most affect its safe operation (brakes, tires, lighting) or that protect drivers and passengers from death or serious injury in the event of a crash (air bags, safety belts, child restraints, energy absorbing steering columns, motorcycle helmets). These Federal Standards are applicable to all vehicles and vehicle-related equipment manufactured or imported for sale in the United States (including U.S. territories) and certified for use on public roads and highways.
What Is a safety-related defect?
The United States Code for Motor Vehicle Safety (Title 49, Chapter 301) defines motor vehicle safety as “the performance of a motor vehicle or motor vehicle equipment in a way that protects the public against unreasonable risk of accidents occurring because of the design, construction, or performance of a motor vehicle, and against unreasonable risk of death or injury in an accident, and includes nonoperational safety of a motor vehicle.” A defect includes “any defect in performance, construction, a component, or material of a motor vehicle or motor vehicle equipment.” Generally, a safety defect is defined as a problem that exists in a motor vehicle or item of motor vehicle equipment that:
=poses an risk to motor vehicle safety, and
=may exist in a group of vehicles of the same design or manufacture, or items of equipment of the same type and manufacture.
Examples of defects considered safety-related:
=Steering components that break suddenly causing partial or complete loss of vehicle control.
=Problems with fuel system components, particularly in their susceptibility to crash damage, that result in leakage of fuel and possibly cause vehicle fires.
=Accelerator controls that may break or stick.
=Wheels that crack or break, resulting in loss of vehicle control.
=Engine cooling fan blades that break unexpectedly causing injury to persons working on a vehicle.
=Windshield wiper assemblies that fail to operate properly.
=Seats and/or seat backs that fail unexpectedly during normal use.
=Critical vehicle components that break, fall apart, or separate from the vehicle, causing potential loss of vehicle control or injury to persons inside or outside the vehicle.
=Wiring system problems that result in a fire or loss of lighting.
=Car ramps or jacks that may collapse and cause injury to someone working on a vehicle.
=Air bags that deploy under conditions for which they are not intended to deploy.
=Child safety seats that contain defective safety belts, buckles, or components that create a risk of injury, not only in a vehicle crash but also in non-operational safety of a motor vehicle.
Examples of defects NOT considered safety-related:
=Air conditioners and radios that do not operate properly.
=Ordinary wear of equipment that has to be inspected, maintained and replaced periodically. Such equipment includes shock absorbers, batteries, brake pads and shoes, and exhaust systems.
=Nonstructural or body panel rust.
=Quality of paint or cosmetic blemishes.
=Excessive oil consumption.
How can I report a safety problem to NHTSA?
If you think your vehicle or equipment may have a safety defect, reporting it to NHTSA is an important first step to take to get the situation remedied and make our roads safer. If the agency receives similar reports from a number of people about the same product, this could indicate that a safety-related defect may exist that would warrant the opening of an investigation. In order to make it convenient for consumers to report any suspected safety defects to NHTSA, the agency offers three ways to file such complaints.
Vehicle Safety Hotline
NHTSA operates the U.S. Department of Transportation’s (DOT) Vehicle Safety Hotline telephone service to collect accurate and timely information from consumers on vehicle safety problems. You can call 1-888-327-4236 or 1-800-424-9393 toll free from anywhere in the United States, Puerto Rico, and the Virgin Islands to register complaints or receive recall information about a vehicle. The Hotline also has Spanish-speaking representatives and offers a dedicated number, 1-800-424-9153, for use by persons with hearing impairments.
soucorp is offline   Reply With Quote
