Old 09-17-2013, 06:39 AM   #20
soucorp
soucorp
soucorp's Avatar
My car came with a K&N, I have done the normal clean and re-oil a couple times with no detrimental effects. I started getting the hunting idle.
I did a complete Throttle body, tubes, MAF (Use MAF cleaner) and now my idle is rock steady
I had switched to a K&N on my mustang and was concerned about the MAF getting fouled but it never effected it
I think you need to see what residue maybe lurking in your throttle body and using some MAF cleaner.
I've used K&N air filters on my Z3 and Z4 without any issues. Porsches and Ferraris are not recommended as the oil particles from the filters will foul up the sensitive sensors. You might get lucky based on how much oil your filter has on it, but its a guessing game and luck at this point. No thanks, not worth the gamble.
soucorp is offline   Reply With Quote
