Thread: Unable to start
Old 09-11-2013, 06:21 AM   #3
HammerESQ
HammerESQ's Avatar
Originally Posted by Rlwalker799 View Post
Lights go out on key turn Battery connections are good w/o corrosion, ignition switch was replaced not Long ago and feels normal. I don't know the location of the clutch switch but if there is a starter , solenoid , or other ignition system fault it deveveloped suddenly without any warning signs/ sounds
The clutch switch is really straightforward, you just have to contort yourself into a strange position to do it (Pelican Technical Article: Boxster Brake Pedal Switch Replacement / Clutch Pedal Switch Replacement - 986 / 987)
The ignition switch is a bit more of a PITA, but also easily done with a few tools and an afternoon (Pelican Technical Article: Boxster Ignition Switch Replacement - 986 / 987)
However - When I had my no-start issue I don't believe the lights on my dash went out when I turned the key. Before buying anything I would check the trigger and 12v connections on the starter, and maybe tap the solenoid with a hammer before ordering parts.
Good luck!
HammerESQ is offline   Reply With Quote
