Thread: Rear Track Arms
Old 09-10-2013, 03:39 PM   #17
woodsman
woodsman's Avatar
Originally Posted by ganseg View Post
If it is the long track arms, is this a safety or handling issue or just an irritating noise?
Both. The suspension controls tremendous forces, especially with the engine overtop of them. The less slop the better. Worn bushings are dangerous and can cause erratic handling. Hitting a bump while cornering on slippery surfaces would allow unwelcome geometry changes and could cause an unexpected loss of traction. In this case, I would think that slop would increase toe-out' while under load just as you mentioned, encouraging the rear end to steer a larger radius than the front and presto, you've got oversteer where you shouldn't. Tight is right- that's why race cars have monoball joints- smooth, controlled predictable suspension movement/ handling.
