Old 09-10-2013, 06:01 AM   #1
Ian c
During your trip , try operating the tip in manual .
Also try stomping it when in auto to see if it sets off in 1 instead of the normal 2 .
And when at a red , push the button to select 1 manually , then make sure it automatically goes into auto mode to change you into second .
Basically , get as much info as you can on the drive , so you can pass it on should they need it for diagnosis ... It will give them a better idea of what is wrong .
Ian c is offline   Reply With Quote
