Old 09-08-2013, 08:03 PM   #17
Ian c
It looks like we missed each other again while I was out today , and you're offline now just as I'm getting ready to watch a movie
Here's a few more quick tests if you're still working on it .
With your meter in the same position , click over to Vdc ... What are you reading volts?
You need to clarify that your drain is 1.7 mA ...
Next do the same check on the alternator connection BATT . What are you reading mA?
(Be carefull not to touch this wire to anything !! The best way is to disconnect the battery then remove and secure the wire with the test leads fitted , then reconnect the battery. )
While you're in this area , a alternator drain can be checked at the same time (preferably with assistance so nothing shorts) . Does the battery mA reading drop when the alternator is disconnected ?
Next reconnect everything and go from the alternator BATT , to ground and set to ac volts . With the engine running and lights on , What are you reading ~voltsAC ?
Now you need to do your first test again
Across the battery with the car running with lights on for a few minutes , what are you reading Vdc ?
What are you reading immediately after turning the car off ?
Turn the lights on for a few minutes , then take a reading again .
Finally , if you can , disconnect the battery completely and take a reading after around 30-60 minutes . Then again in the morning .
Ian c is offline   Reply With Quote
