Old 09-07-2013, 09:44 PM   #21
cas951
3point2,
Your chrging seems fine to me. As long as the Alt output is 14+ volts with no load you should be fine. If you want to test further let the car idle, turn on your lights, AC, and other accesories to see what voltage you have at the battery.
You should have 13+ volds.
What you have is a drain when the car sits for awhile which drains your battery. This is why Ian and I suggest you use the voltmeter and pull your fuse out 1 x 1.
If you don't find the culprit from the fuse the likely cause is either the starter or Alternator or bad Ing switch.
2008 Boxster S PDE2
02 Boxster S Blk on Blk(Stock for the Wife)
88 turbo S (My Toy) slightly modified
cas951 is offline   Reply With Quote
