Old 09-07-2013, 04:19 PM   #11
Ian c
Yeah
That's exactly how to do it .
One at a time and replace after noting the reading .
You should be reading around 20-25 milliamps so if you have a smaller range on your meter it will be fine .
The idea is to find how many mAs your car drains with all doors shut and locked (simulating a parked scenario)
And if it is high enough to flatten your battery you pull one fuse at a time to find out which circuit has a fault causing excessive drain
Ian c is offline   Reply With Quote
