Old 09-07-2013, 03:23 PM   #11
Ian c
I can't see properly as I'm in the car on my cell , but it looks like dCA ?
If it is , that is dc amps . Perfect.
Disconnect the ground as described earlier and take a reading .
Make notes and remove fuses one at a time and note what it goes down to .
I forgot to add earlier . Your meter co. e toons must be good .. If using probe pins scrape first and if using clips lamp them on the. Use the grips to clean the surface .
I will be home in an hour so will call back on here but hopeful someone else will rey a out your drain readings if you're having trouble
Ian c is offline   Reply With Quote
