Old 09-07-2013, 02:10 PM   #3
mountainman
mountainman's Avatar
Originally Posted by valiantechoes View Post
Do I understand that no noise turning right means the left rear bearing is ok and when turning left with noise means the right rear bearing is bad? Thanks for the help.
If the rear bearing is bad the noise will become more pronounced when you turn in the opposite direction from the bad bearing. Noise when turning right means bad bearing on the left. Noise turning left, bad right bearing.
mountainman is offline   Reply With Quote
