Old 09-07-2013, 11:15 AM   #3
Ian c
Originally Posted by Ricurb View Post
Rear solenoid hasn't worked for a year.Not even hearing a click. Took read driver tire and tire well liner and looked all over but no emergency cable release. I am at a loss what do do next
I will meter the switch on mine later , as I've never investigated it .
But I suspect it will be a simple 12vdc+ on/off switch .
If you have power there and a bad switch it can be shorted .
If you have no power there you can supply it with a temporary jumper .
If you have power and a functioning switch its the latch at the rear , which will leave your emergency release as the only option .
Your emergency could have simply been rerouted as a convenience or anti-theft procedure .
Many reroute the front behind the tow-hook cover for easy access for example .
Ian c is offline   Reply With Quote
