Old 09-06-2013, 07:51 AM   #2
spendy
There are more knowledgeable folks than me around that will probably weigh in eventually. But I'll put my non-expert info out quickly:
Don't use your torque wrench for the +120 as you may damage it. A breaker bar is a better tool to use.
Probably an oversimplification, but the way I look at the balancing is that if you have two things that are balanced individually, the assembly will be balanced when you bolt them together.
spendy is offline   Reply With Quote
