A drift to the right is usually caused by the normal "crown" of most roads that aids water drainage to the right. After setting all tires to the same PSI used during the alignment, drive on a flat road with no crown like the middle lane of a 3+ lane freeway.
If it still drifts, the wheel bearing replacement procedure may have altered a alignment setting.
