Old 09-03-2013, 08:26 AM   #10
AKnowles
AKnowles's Avatar
Glad you got the relays. As an FYI though, often you can repair a repair. Resolder the contacts on the board if a cold/damaged joint or by using fine grade sand paper on the contacts if worn. Often heat build up and failure is a sign of poor contact surface area. I've never had to resolder joints, but have used the sand paper method on relays and ignition points before when stranded. I've always replaced them when an opportunity presented itself so couldn't say how long the fix might last.
