Old 09-02-2013, 07:17 AM   #3
thom4782
thom4782's Avatar
If the parts are plastic like and you conclude it's normal wear, check your camshaft deviations to see if the wear is excessive. Anything greater than +/- 6 degrees is out of spec. If so, then you should consider changing the pads.
