Old 08-26-2013, 03:28 PM   #1
Marty S
Marty S's Avatar
Send a message via Skype™ to Marty S
Help....Possible electrical problem
I went to dive the car last evening and could not get it to start. No power what so ever. Appears to be a battery. I took the old battery to Advance Auto and sure enough, the battery was dead. Hence, I bought a replacement and ran home to install. As soon as I connected the positive, I could hear a bell and expected to see the car coming back to life. When I got in the car, the airbag light was on and I could hear something that sounded like a fan running,but the car would not start.
When I turn the ignition, nothing, not even an attempt to start. No radio, no lights, no climate control, locks, windows. Dead as a door nail. I called my local independent mechanic and he suggested it could be anything from a bad ignition switch to a blown fuse.
When I put the new battery in, I connected the negative first and then the positive. I dd notice a little bit of an electrical spark when the battery was connected. Otherwise, nothing else. Since then, I removed the battery, it is sitting in the frunk and the car is on its way to the shop via a flatbed.
Anyone car to guess what might be the issue? I am hoping for the fure or something simple, but that is usually not my luck. By the way, the old battery was 4.6 years old..
THANKS
1999 Boxster
2102 Fiat 500 Sport
2013 VW Touareg TDI
Marty S is offline   Reply With Quote
