Old 08-24-2013, 09:09 PM   #13
coreseller
M9622 -65YA - your engine is an M96
A8605-13 - your transmission is a Tiptronic
You'll have to get the engine number from the block.
TO
Haz, If I remember correctly it was on the passenger side (USA version) of the motor and I had to clean the smooth portion of the block on the lowest section of the motor to read it with s degreaser or thinner of sorts, the numerals are of the stamped sort with multiple pin stamps per. Once you get under there and look around and rub with a towel it should become obvious.
