Old 08-24-2013, 02:32 PM   #11
smshirk
Originally Posted by SpyderRS View Post
Hi,
the RW5 rim in 19x11 offset 40 fits with a 8mm spacer, but i donīt think, that`s possible with a 295 tyre... however... in this configuration only a 265 or 275 should possible, because the 295 would be scratch outside on fender and perhaps inside on the strut. If you want to get lowering your boxster, keep in mind that each rear fender must be widened for 1" and needs a more negative camber!
I have a set of 18 x 11 with 295 tires I tried once just to see. No where close to fitting. Rubs everywhere and that was before I had the m030 suspension
2001 Boxster S 3.6, 2003 E46 M3, 94 968 Cab, 80 911 Weissach Edition, BMW 1200 CLS
smshirk is offline   Reply With Quote
