Old 08-24-2013, 05:38 AM   #10
haz
haz's Avatar
Originally Posted by trimer View Post
Man I am hoping for the best for you? Remember, just fixing IMS may not be the best option. If there is that much material in your filter, most of that was running through your engine and might have scored the other internal parts. Good luck on this...
Ok Iīm getting nauseous at this point... but thanks, I guess
Originally Posted by kjc2050 View Post
This should help: http://986forum.com/forums/general-discussions/44248-understanding-vin-codes-engine-numbers.html
Also, see the chart in this article: Pelican Technical Article: Boxster Intermediate Shaft Bearing Replacement and Upgrade (IMS) - 986 Boxster (1997-04) - 987 Boxster (2005-06)
I have a 2000S and it has the dual row bearing. The engine number is stamped on the bottom of the block near the sump plate. Good luck!
I need my engine number first, this sticker on my passenger doorside didnīt help much (there was no sticker on the drivers doorside)
haz is offline   Reply With Quote
