Old 08-23-2013, 09:44 PM   #11
schoir
Originally Posted by jesseborgelt View Post
So, without taking the car apart to visually see, how is someone going to know if they have one or two rows?
As long as you are certain that the engine is original to the car, all model year 1997 to 1999 Boxsters have a dual row bearing.
If you go further and remove the transmission, you can identify a dual row bearing by a narrow IMS flange.
Model years 2000 and 2001 are a tossup as to which IMS bearing is in there. You can only be certain there by at least removing the transmission. If you find a wider, more offset IMS flange, then there is a single row bearing installed.
Regards, Maurice.
schoir is offline   Reply With Quote
