Old 08-01-2013, 09:20 AM   #3
oc-boxster
oc-boxster's Avatar
Originally Posted by heymanwatchthis View Post
I just went through the same thing!
Remove your headlights (very simple) and you will see some alignment tabs where the top of bumper slides into. You are likely not getting top lip of bumper into these tabs. This is easy to miss as the tabs cannot be seen without removing the headlights - and is frustrating because everything seems to be lined up just right.
When I discovered this the bumper mounted perfectly. Good luck hope this helps.
Heyman, just pulled my headlights and sure enough the bumper was not under the tabs just removed the top 2 screws by the latch and pushed the bumper under the 3 black tabs on each side-much better now! Thanks. Glad I know how to remove and replace headlights now-much easier than I thought.
oc-boxster is offline   Reply With Quote
