If the car sits for enough time (7 days I think?) Some of the remote functionality turns off to save battery. To restore it, use the key to manually open the car door (and maybe crank too). Sounds like you have done that already but if not something to try.
The battery in the key is very easy to change, you can just gently open the key with your fingers by using your fingernails to pry it open.
I changed my batteries when I got mine, and they both worked (and the red light was flashing in the key even before I changed the battery)
Right now one key works and the other doesn't for me; I think I wore out the battery on the key I use the most.
Good luck!
Steve
