Originally Posted by an6box
On the left one, when I open the door from outside, the glass doesn,t go down quickly and then it touch quite hard the garnish opening the door.
How quickly is "quickly? There is suppose to be like a full second delay. Many times I find that this is due to user error so be patient.
If not then it sounds like the begining of a regulator malfunction. Are you getting streaks on the winow too?
On the right one, when I open the door, from both inside and outside, the window go down and then come back up even if the door keep opened; then when you close it, the glass knocks on the garnish.
I would suggest taking it to a Porsche Service and have them look at it. It could be the window regulator or relay. Parts and install of the window regulator should cost around $300 if I remember correctly(its been a while since mine went out).
