Old 07-25-2013, 06:17 AM   #2
truegearhead
truegearhead's Avatar
Both shops are mistaken because the o2 sensors aft of the cats only sniff for emissions and don't affect mixture trims. I would disconnect the batt again for one minute to reset the DME and see what you get. Is it possible you crossed the pos/neg terminals and fried your DME?
No the cords don't reach. This happened once before a month ago and I towed the car in and it was diagnosed with a bad air/oil separater. After the fix it ran, then once I dissconnected the battery again..same thing all over again. I've dissconnected it numerous times and connected them to discharge and capacitance..no luck. Very odd problem. Are you sure the aft O2's don't effect mix?
1997 Boxster 4.2L Audi V8 Bi-Turbo
2003 911 C2
NASA HPDE Instructor
truegearhead is offline   Reply With Quote
