Old 07-24-2013, 02:44 PM   #2
chipmunk
chipmunk's Avatar
French Dude, what do you mean that nothing was wrong? You can't see a dry joint unless you look closely and even then you might miss it. What you need to do is to resolder (carefully not to overheat the transistors and capacitors) all the major joints you can see and then try it again. Intermittent problems are often caused by bad connections that expand and contract with heat.
2003 Boxster S
chipmunk is offline   Reply With Quote
