Thread: Connects2 Kit
Old 07-24-2013, 08:47 AM   #1
Nimbus117
Nimbus117's Avatar
The only thing you will use is the fascia as the headunit comes with a cage. I got this kit and got rid of it after a week, I found the lug which holds the fascia wears after you remove the fascia a couple of times and doesn't hold it in place well enough. In the end I bought a fascia plate off Trieullionaire on Renntech and is a much better fit no matter how many times you remove it.
Wiring converters are ok if you can find one that is correct. What speakers and headunit do you have now? I had the CDR23, that had the rubbish MOST system in and meant I had to replace the amplifier.
Sorry, not tempted to pop over and give you a hand - unless as mentioned already, you secure the services of the wash girls.
2003 Boxster 2.7L
2010 Civic Type R
Nimbus117 is offline   Reply With Quote
