Old 07-22-2013, 01:23 PM   #10
TeamOxford
Damn Yankee
TeamOxford's Avatar
Originally Posted by dbansal View Post
Also, I'm thinking of buying the oil/filter myself, and also a magnetic drain plug and giving it to the mechanic to put in.... Recommendations on oil/filter/magnetic drain plug and where to buy??
You can get your filter and the magnetic drain plug from Pelican Parts. You'll also need to get a crush ring for the plug. They're very inexpensive, so you might want to stock up. If you choose Mobil 1 as your oil, you can get 5 quart jugs at WalMart for $22.47 each. You should be able to find most other oils at your local auto parts store. The exotics will have to be ordered.
My last change cost $65.00.
TO
