Old 07-22-2013, 03:23 AM   #1
opus69
Pilot bearing is for the front main shaft of transmission where it inserts into flywheel and in my opinion should be changed with a new clutch. It is cheap and you already have access. Throwout bearing rests against the pressure plate of the clutch and disengages the clutch when pedal is depressed.
opus69 is offline   Reply With Quote
