Thread: Code 4276
Old 07-21-2013, 01:08 PM   #1
opus69
Code 4276
After the car sat for several months the battery went dead. After a slow charge it started right up but gave a code of 4276 on the Durametric. The ABS failure light and low brake fluid level lights are on. I tried to delete these codes with the Durametric but it will not communicate with the module. It reads the codes but I can not reset them. The brake system is in good condition, pads rotors etc. Fluid level is good. The 4276 code indicates a low voltage to one of the ABS valves. Battery voltages were good when checked with digital voltmeter. Also good when running so I think I have ruled out battery and alternator. I think it must be something electrical that was triggered by the battery going dead but so far no luck. Even tried disconnecting battery to attempt a reset. Unless it needs to be left unconnected for a longer time I could not get the codes to reset. Any thoughts?
ABS/PSM 5.7
Module Identification
Part Number 996.355.755.05
Supplier Part Number 12
Current Fault Codes
4276
Valve supply voltage
opus69 is offline   Reply With Quote
