Old 07-20-2013, 10:01 AM   #1
jsceash
jsceash's Avatar
While the car is apart for the RMS/IMS/clutch, the AOS is right out in the open and can be changed in about 5 min. I would also look at the oil fill tube as they are a common problem, and are also exposed while the car is apart.
+1 on this. The 2 spring clamp that are almost impossible to reach on the 90 degree tube at the bottom is easy to reach with the trans, out!! Really makes this a 10 minute fix.
