Old 07-09-2013, 09:50 AM   #15
The Radium King
The Radium King's Avatar
three culprits I can think of:
- over-temp - cyls go oblong and pistons score cyls
- bad aos - no vacuum to crankcase so piston rings don't function properly; pistons score cyls
- over-rev - all bets off
I don't think engine mods will have much effect unless they push you into a lean condition and start making thinks hot, or timing goes off. from what I've seen (check out insite's wideband o2 post) the ecu tends to keep even a heavily modified engine in the safe zone.
