Thread: Horn Problem
Old 07-08-2013, 09:43 AM   #14
les
I am about to replace for the 3rd time ('99 with 105k). First time I tried all the fixes to beef up the rubber grommets that were failing. Worked for awhile and then failed. So I got a new bracket. Just a crap design. Air bag weighs too much and it will eventually wear out the thin rubber. Right now it is beep/beeping when it gets really hot out and the rubber becomes real pliable. Soon it will happen even on a cool day. I found a Torx unit at Home Depot that was long enough to engage for under $10 and has multiple other Torx heads on it as a bonus.
les is offline   Reply With Quote
