Old 07-05-2013, 05:10 PM   #1
schoir
Originally Posted by Hayden View Post
Yeah, it's stuck open. I will need to find a larger wrench. Thanks for the prompt reply!!
edit: got larger wrench. No way it's fitting in there. No box wrenches in that size at Lowes either. Tired of throwing money at this. Off to the mechanic... which I think is pretty ridiculous for something that is outlined in the owner's manual, which can't even be remedied through the way it says (since apparently, disconnecting the V-lever is the only way to get the ball connectors off.)
Sears sells the 19mm offset box wrench that will fit perfectly on that bolt, in that position...
It looks like this one in the photo.
Regards, Maurice.
schoir is offline   Reply With Quote
