Old 07-05-2013, 04:50 AM   #12
eli cash
eli cash's Avatar
Originally Posted by thom4782 View Post
Are you aware of the IMS bearing issue?
Low mileage cars tend to have higher rates of IMS bearing failures than higher mileage cars. If you replace the IMSB alone as a preventative measure, it will cost about $1800. If you add a new clutch into the mix, then add another $600-$800 to the total cost.
You might use this piece of information to push the price even lower. In my locality - northern CA - a base Boxster goes between $14K and $16K for a private sale. Trade in value is about $2K less.
If the seller is asking $11K, I'd offer $9.5 and use the difference to replace the IMSB given the prior damage.
Yes, I was actually already thinking that. With a new clutch, I understand the point is to save money by already being in there, but would that be necessary at 50-60k?
eli cash is offline   Reply With Quote
