Old 06-21-2013, 08:08 AM   #1
recycledsixtie
recycledsixtie
recycledsixtie's Avatar
Originally Posted by soucorp View Post
I don't think a Durametric code reader will tell you where the noise is coming from, if anything shows up, it will show you what to look at as those monitored items are being tracked and has caused a detectable fault.
For example, if its a bad bearing in the waterpump, AC compressor, tensioners those items would not show up but you will hear it.
Yes I will pick up a stethoscope to check out the noise. Can you make any generalizations as to what can cause a noise at idle and then disappear as the rpm's
are increased above idle? Water temp shows normal so far.
