Old 06-12-2013, 02:49 AM   #18
insite
ok, ran test points & did tuning. the logworks program is calculting power & torque using gear ratios & RPM. problem is, i still can't get the RPM channel to log with a frequency greater than .83s. it's choppy. the program has a smoothing function, but there is a great deal of sensitivity to how the data is chopped up.
i developed a method that is consistent; i used it across the board for these graphs. don't pay too much attention to the absolute numbers. just compare the output. the thick line is the baseline run. also of note; the percent AFR change on the fuel controller does NOT equate 1:1 with an actual change in AFR. i had to play with it a lot to get the test points i wanted. here are the first seven;
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
