Old 06-08-2013, 09:23 PM   #6
schoir
Originally Posted by jccash View Post
I am also having a water leak issue. I have replaced the plastic drain trays on the passengers side under the top. I can see where the water is getting in. It's like the it just pours over the tray over the seatbelt mechanism. The tray drain plug is clear but its almost like I might be missing a part or something. It's the same on both sides. Here are some pictures. The first pictures shows where the water is coming inside from the outside. The 2nd poor picture is the drain tray and the their picture is where it spills over the seatbelt mechanism into the passengers seat area.
Aside from the two drain holes at the bottom of each drain tray (below the V-levers), there are also two drain holes INSIDE the channels into which each side of the clamshell slides over. If those drains clog, rain (or hose) water will overflow quickly into the area near the seat belt mechanism.
You will find the drain holes at each forwardmost outboard corner of the channel, ahead of the small plastic height adjustment mechanism. Those drain holes empty into a tube that terminates on the outside of the forward part of each rear wheel, under the small plastic wheel liner. The water should drain just forward of the rear wheel if the drain is clear.
Regards, Maurice.
schoir is offline   Reply With Quote
