Old 06-07-2013, 05:53 PM   #2
AKnowles
AKnowles's Avatar
Originally Posted by jsceash View Post
You do realize the gaskets are stainless steel edged in Viton.
By using the term gaskets, I used it rather losely and should have also included O-Rings and other components. Bottom line is it is NOT recommended to use E85 in any vehicle not expressly certified for E85 use.
BTW: I've loked at some pictures of the engine gasket kists. Out of curiousity mostly. Are you saying all the gaskets show are steel lived with Viton? Or should be to meet OE specifications? If so, I'll have to keep that in mind if I ever buy a rebuild kit.
