Old 01-14-2006, 03:25 PM   #1
MNBoxster
Hi,
This is definitely a DIY Project. Proceed as follows:
● Turn Ignition ON
● Push Shift Lever Button and Insert a small Allen Wrench Up under the Button from below.
● Press down on the Allen Wrench to Pry out the Shift Button
● Underneath the Button (once removed), you'll find a Spring and Clip. Remove these (noting the orientation of the Spring) and lift off Shift Knob.
● Using a Plastic Pry Tool (or carefully using a Screwdriver) insert under the Base of the Shift Plate and Pry this off.
● Install New Shift Plate by snapping it into position
● Install New Shift Knob and reattach Spring and Spring Clip (again orienting it as before)
● Snap Shift Button back in place on New Shift Knob.
You're done - Total Time: 5 min. Hope this helps...
Happy Motoring!... Jim'99
