Old 01-12-2006, 12:39 PM   #3
MNBoxster
Originally Posted by jiggysubman
i have a 97, it doesn't have any factory alarm, just the central locking system. I did replace a window regulator on the drivers side almost 9 months ago, and i did remove the door locking mech. to look at it, but would the problem take this long to surface? I wonder, if I replace the lock mech. with another one, will it still take the same key, or does it have to be re-coded?
Hi,
Before you go replacing the Lock Mechanism, did you reset the Spring Guide when reinstalling the Lock? If not, I'd try this first. Would it surface after so long a time...?? Who do I look like... F. Pieche..?? Give it a try, also, check all grounds, fuses, connectors, etc. Good Luck!!...
Happy Motoring!... Jim'99
