Old 01-12-2006, 08:01 AM   #1
MNBoxster
Originally Posted by jiggysubman
when i put the key in the driver side door to unlock the car, it only unlocks it mechanically, ie the light does not come on, the window won't come down its 1/4" and the other door wont open at all. When i do the same thing on the passenger side door, it works just as it should. Also, if i open the door from the drivers side, and start the car, lower the window, and begin driving, the red light on the lock button will illiminate periodically.
Is this a problem with just the drivers side door lock? Or Is this a problem with central locking in general? Anyone had this problem before? Any fixes?
Hi,
First, it helps greatly when asking a question to identify your Car's Model Year and any relevant Options as there are many variations to the systems of the Car(s) - Help People Help You!
One thought I have, has your Door recieved any kind of Service? The symptoms you describe match those associated with replacing the Door Lock Mechanism in the Door.
There is a Guide Spring which runs from the Lift Actuating Lever to a Spring Hook. When reinstalling the Door Lock, you need to reconnect this spring to the Door Lock Mechanism prior to installing the Lock Mechanism. Failing to do this can result in problems with both the Central Locking Function and the Alarm/Window Drop Systems.
Note: This Spring automatically disengages the 1st time the Door Lift Handle is used, so if the Lock was removed, the Spring would be in it's Normal disengaged state and if the Service Person was not aware of it's function, they may not have reset it when reinstalling the Door Lock Mechanism.
The Fix entails removing the Inner Door Panel (after disconnecting the Battery and waiting 1 min. so you don't trigger the Airbag), removing the Lock Mechanism, resetting the Spring and then reinstalling everything. Not very difficult, need a T-25(?) Torx Driver and a Plastic Pry Bar to remove some of the Panel Trim. Total Repair Time - under 30 min. Hope this helps...
Happy Motoring!... Jim'99
