Old 01-11-2006, 06:54 PM   #11
deliriousga
deliriousga's Avatar
Originally Posted by MNBoxster
John,
The Bar sits directly behind the Battery and does not interfere with the Inspection Covers at all. Easy install - remove 2 of 3 Bolts (13mm) from the Struts (keep the one tight to prevent losing the Camber Setting). Install the Brackets, retighten Strut bolts to 26 ft. lbs., and then attach and adjust the Bar. Total time - under 10 min.
Happy Motoring!... Jim'99
Fantastic!
Thanks Jim
1966 Wife White/Brown Top
