Old 05-13-2013, 04:29 PM   #11
moresquirt
Great read!! I have an 06 Boxster S with 60k and want to keep it for a very long time so adapting an IMS fix is definately on my bucket list.Jake Raby,your the man,and thx for all your work ,support and incredible design work because waiting for Porsche to help is obviously not in the cards.When do you think the IMS SOLUTION will be available for the 06 thru 08 late design IMSB.I have not needed any clutch work as off yet but was considering a comment you made on another site regarding just pulling the outer bearing seal which would at the very least lube the bearing if the seal failed.Could you comment on why the feed line location that Tuner Motorsports uses was less than ideal for the IMS SOLUTION.Thx
Warren H
Ontario,Canada
moresquirt is offline   Reply With Quote
