Old 05-01-2013, 06:18 AM   #14
insite
quick update. i got the AFC computer installed & initialized. my wideband is acting up; i called innovate & they gave me a reset procedure which i will try this evening. i had to swap out my cat bypass pipes for the cats; my emissions are due this weekend! once i get the bypass pipes back on the car, i will do some tuning.
earlier, i mentioned data rate issues. the data coming in from the ECU was slow & i had to apply some smoothing to get good results. i brought this up to the innovate guy when i called them about the wideband. by default, the OT-2 computer (the one that montors the ECU & outputs to the iPad) is set to 'Auto' for OBD II protocol recognition. his suggestion was to change the setting to ISO 9141. i did this...and it worked! nice, smooth data.
once i get the test pipes back on & the wideband reset, i will do a baseline dyno again. i will also start re-logging baseline fuel maps & begin logging power vs. AFR. good times.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
