Old 01-09-2006, 05:59 PM   #1
deliriousga
deliriousga's Avatar
The only recall I know of for the 2000 MY is the gas cap. It's "Porsche emmission recall A209". They replaced the gas cap because some were not holding pressure during the emmission tests so the cars were failing.
There are several TSBs, way too many to list. Most are just annoiances with the top, squeeky pedals, remote range etc. The most important TSB has to do with the RMS leak some have experienced. They replaced several bolts in the crank case with different, coated bolts when a leaky RMS is replaced. If you don't have the leak, you don't need to worry about it.
1966 Wife White/Brown Top
