Old 04-30-2013, 11:54 AM   #3
Gilles
As long as you have not allowed air to enter the ABS/PSM pump and control network, or have just replaced any parts there, there is no need to cycle the system with either a PIWIS or Durametric software.
JFP, just out of curiosity...
If you install a GT3 master cylinder and use a bleeder system that PUSHES the fluid from the bleeder back to the reservoir do you think that you may get away with a proper bleeding without activating the ABS/PSM pump?
Your comments are always appreciated.
