Old 04-27-2013, 06:46 PM   #2
Timco
I am my own mechanic....
Timco's Avatar
The idle bounce could be a number of things but I would get the throttle body cleaned first then test for vacuum leaks.
The rattle could just be chain tensioners.
I have no direct experience with IMS bearing failure but you will have a significant leak on the underside of the motor, then at some later point in time there will be nasty grinding sound just before the motor chews itself to pieces.
I agree with vac leak / dirty throttle body.
'08 VW Touareg T-3 wife's car
