Old 04-22-2013, 03:03 PM   #11
CA_Boxster
Originally Posted by evo-r View Post
What are the symptoms of a failing water pump?
If you're lucky then you hear muted grinding sounds like there are some pebbles caught in the underbody. This is the sound of the impeller starting to break into pieces.
If you're less lucky then you're driving and the car overheats because all the coolant leaked out slowly over time through the hole left by the broken impeller
CA_Boxster is offline   Reply With Quote
