Old 04-21-2013, 07:47 PM   #2
Dr.Strangepork
Dr.Strangepork's Avatar
Originally Posted by jsceash View Post
First there is a U-Tube video set that someone with a cracked cylinder made. The problem with that was no real specs or clearances or torqueing specs. I purchased a Porsche manual for the 2005 - 2008 Boxster it was the only manual out there that covered the 3 chain engine. This had all the clearances. It gave all the torque specs for every bolt in the engine. The timing procedures and it shows what tools you can't do without. It was very good for removing and installing the motor and transmission. My suggestion for anyone going to attempt this is view the video. Then buy a comprehensive manual. I've had many years of experience building motors, a good manual is a must.
Thanks for the info
Dr.Strangepork is offline   Reply With Quote
